alternator body-to-engine block ground wire
golf73
not sure where to connect this brown wire to the engine block? wire seems too short to reach anywhere that will have a bolt small enough to fit the diameter of the hole in the connector. if anyone has a picture or can describe location it would be very helpful. in the middle of this right now - want to wrap it up tonight.
Picture in the Blue Book describes the ground wire secured under the lowest bolt on the upper timing cover (closest to the alternator) - this is for carb-equipped engines.
Tii engines (I believe) used the upper alt. pivot bolt to secure the brown ground wire.
thanks, jim. what page in blue book is that shown? i'm wondering also if it's possible to ground the alt. body to one of the B+ posts? i think that's where it may have been prev. mounted although now i see it will reach to the timing cover bolt you mention (it's a little hard to get to as i don't have elf hands but i'm filing down the bolt and washer with emery cloth to get a good clean connection).
because I could not remember.
No wonder, I do not have that ground wire. Wonder how everything is working on mine?
Does anyone have a picture of this wire and where it is connected?
1972 2000tii Touring #3422489
FAQ member #5
there's a bolt (long thin) that protrudes 1/2" beyond the casting on the alternator. Both my 75 (now sold) & 76 required a ground wire from the that bolt, to chassis ground of the vehicle. I also was missing this wire on my 76, and was surprised it was working previously. I made my own wire, long enough to run to the ground point near the relays next to the battery/brake lines. You have a few ground wires attached there already, on a metal tab. And mine is working perfectly. I actually ran 2 strands of 18 AWG (I think), just for good measure.
I also wired an alternator to my buddy's 74, same way, and his daily driver is working perfectly. 3 for 3, so I guess it's good.
Scott
"No, Dave, I can't let you do that..."
as b+ is battery +...
ah ha...still i'm curious why there are two B+ posts on the alt?
bill, i took some pictures tonight, check them out to get an idea.
Now I need to get that ground wire on the touring.
Thanks for the pictures Dave. Putting the wire on B+ would let the smoke out. Once out, you can not get it back in. I have seen the machine at the wire factory that puts the smoke in the wires.
Jim - do you know for sure where the ground wire grounds on a tii? I need to make one up and get it on.
FAQ member #5
Thanks for your addition CD. I was just looking at that picture on my laptop.
Also (related to your pic): Notice the clamp secured to the lower #4 intake tube - what's that for? Is it for a wiring harness or hose??
