How to remove arm of steering box from linkage?
Germanmd
I am removing my steering box for rebuild and cannot seem to break loose the arm of the box from the steering linkage. I have used a puller and can't get it to break free. I was wonderig if anyone had some thoughts on how to get this removed. This is the last step that is stopping me from driving my freshly painted restoration I've been working on for 10 years. My wife thinks I'll never finish it and I've got to prove her woring. TIA, Dan
Dan in Philly
1972 02 Automatic
Hi,
the easiest way to remove the steering arm from the
center tract rod is to hit the steering arm squarely on the side
with a regular hammer and after a few hits the cone shaped
part will drop out of the arm. the other choice is to buy
a pickel fork and drive that into the joint between the two
parts. the second choice is harder on the parts if you plan to
reuse them.
good luck
stone
stone racing co
phila pa
215.520.6718
stone racing co
phila pa 19123
Hi,
reuse them.
good luck
stone
stone racing co
phila pa
215.520.6718
this method will work for sure and harbor freight has the forks for about $10.
this will however cut the protective rubber boot covering the ball joint
72 2002tii
1988 535is  “Maeve”
I use a variation of the hammer method, but use 2 hammers. Hold one against one side of the joint and whack the other side with the second hammer. May take a few tries, but never fails. Does not damage the boots either.
BMWCCA #2762
72 2002/71 2002ti, 67 2000CS, 2x 72 3.0CS
86 635, 2x 05 330Ci ZHP,
'11 Corvette Grand Sport
