Desmogging - What to keep, what to kill
moloko
I'm soon to begin the arduous journey of removing the smog equipment from my 1975 2002. The previous owner did a good job of hacking everything up and making a mess of the engine compartment so I'm not totally sure what's there and what isn't. The car has a 32/36 retrofitted with a manual choke.
I'm wondering what needs to be kept absolutely so that I can get everything else out of the way. I have a tii exhaust manifold to get rid of the egr/thermal reactor and I'll be pulling out the air pump too. I'm not sure what to do with the vacuum relays. From what I've read one still needs to be in place, but I'm not sure if that only applies to Solex carburetors. I'm also concerned about the vacuum advance--I think it's already hooked directly to a vacuum line off the carb instead of a relay, is this the way it should be?
Thanks for helping, there really should be an FAQ about this stuff, too.
Somewhat related: I'm looking for a place to get the rubber mounts for the air filter housing. Does anyone know a place where these are sold?
I pulled it all, including all the vacuum relays.
My carb goes directly to my advance on the dist. and the dist. retard is plugged.
Air pump, EGR assembly, air check valve, all pulled.
People say to keep the fuel vapor recovery stuff (if you have it), mine was removed for me by PO.
Nice to know I can pull it all then. I'll probably keep the vapor recovery because it's completely functional and I'd rather not smell like raw gas.
It's been a while since I looked, but I remember there being only one vacuum line coming off the distributor. Where exactly is the port for vacuum retard located?
"Pulling it all" is silly over-simplification to the original post. What is the goal in removing smog related equipment? Weight reduction? Enhanced performance? Reliability?
Sight unseen, I would think the best approach would be an attempt to return the engine to its European format which was designed to operate without most of the US required smog equipment. That does not just include air pump removal (which some advocate is not a good thing) but also increasing compression, altering carb jetting and most definitely altering the ignition advance curve. Singling out electomagnetic valving that sits on the firewall that is no longer attached to anything affecting engine operation is like reminding the Moose to remove the lint off of their antlers to make them more effective.
No, I'm just removing it because the previous owner did a hack job of desmogging it himself The EGR piping from the exhaust manifold was clamped off, hoses were simply cut--it looks like shit.
I don't care about getting it to euro-spec or whatever, I just believe that ridding my engine from a bunch of needless or broken components to make it look more decent is worthwhile.
