How to remove windshield wiper motor assembly?
jafcorrea
you have to remove the entire wiper assy...a tricky procedure...i don't know about the wiring differences but the motor is attached to the linkage assy...take off the wiper arms, remove the large chrome nuts and finagle it out, past the heater motor
Hi Esty
Is not only the motor sorry is the entire assembly, I need to swap, let me know if you did this before.
Thanks all ........... JCorrea
Well I got the wrong wiper assembly (this one has 5 wires), my has 4 wires and is a 1970. (switch have 3 position (off, slow, hi)
The first question remains, How to remove the entire assembly (motor & arms)??
And is possible to install the wiper assembly (5 wires) in my car? If yes how do I connect?
I just had to remove the motor assembly. I simply pulled out the motor by removing the 3 screws that hold it to the arm assembly, then one screw that keeps the shaft connected to the arms.. It is fairly easy, you may have to move the wipers manually to gain access to the screw in the back. When you install the new one, connect the motor,but not the wiper arms, turn it on, and turn it off, so you "locate" the motor resting position. Install the wiper arms near the bottom. but not totally since they go down a little when you turn the wipers on. Use a flashlight so you can see (this may not be obvious)
as far as the electrical stuff, I don't know.
FAQ Member # 91
The old one has 4 wires and the new one has 5, how can I install?
not so much with the easy.
The later motor works completely differently than the early one.
Your best bet would be to convert to later switches and wiring, too.
Search a long, long way back and there's a good write- up.
