Differential Identification
nfinsness
I was given a rear end with diff...was told it was from a 318i. Could anyone tell me whether it is an LSD and whether it will fit in my 73 02?
Numbers on it read:
HHI 80
12077 719 GGG-40
Photos attached...
Thanks,
Nat Finsness
-1973 BMW 2002 Malaga 34,000 miles...finished!
-1965 Pontiac GTO 389 4-speed
-1964 Pontiac Lemans Convertible 326 Auto
and you want the bits running down the left sideof this diagram
- remove the rear cover and look inside for conformation.
You need to remove the cover anyway to gunk it out,
and inspect for missing teath, or broken bearing-bits
'64 R27 250cc #383851 18,000m
the easiest way to see if it is a LSD is to remove the rear cover and look inside!
I second the above.
Remove the (6) 17mm bolts on rear cover (careful not to spill goey gear oil); an LSD diff will look like the image below.
"S" stamped and/or painted on diff case indicates "slip" a/k/a LSD. Numbers on case indicate gear ratio, the "H" number on the ring gear does same.
I second the above.
and i would add my 2002 LSD, not a 320i LSD, does not have the "S" stamp
72 2002tii
1988 535is  “Maeve”
