Can an imbalanced driveshaft destroy a guibo?
ClayW
The main problem is when the flanges are bent so that the bolts aren't quite straight, and it distorts the guibo a bit. (it doesn't take much)
Bring a Welder
I've been through a few guibos for various reasons (improper installation, age, etc.) over the years and I'm curious if an out-of-balance driveshaft might be contributing.
Yes, for sure. Also, a bent flange, a loose bolt, or bad alignment of the center bearing (no preload) or side load on the Guibo ( I did this by not having the driveshaft forward enough based on the adjustment from the diff carrier.
70 M2 2.5L
INCORRECT INSTALLATION OF THE GUIBO
more likely :
metal installating band needs to remain wrapped
around the disk untill all nuts/bolts tightened
alternate the bolt head and nuts ,
and with washers under nuts
DO NOT USE GENERIC hardware
Special shouldered, high tensil OEM bolts only
with "fresh /new' nylock nuts - and with Blue
Threadlocker
tighten the bolts only with the center bearing up
and in place, and trans motor in correct INLINE positions.
'64 R27 250cc #383851 18,000m
Preload? Please explain!
Or, better yet, can somebody write a quick, step by step instruction on guibo replacement? I suspect that most don't understand what can and does go wrong.
ClayW
Well I don't have my blue manual handy right now, I'm sure CD can supply the picture, but you should be pushing the center bearing forward in the bracket before tightening...my memory is by a few mm.
70 M2 2.5L
Tighten only the nuts. Do not rotate the bolts.
Rotating the bolts will twist the metal sleeves in the rubber, leading to early failure.
Too many cars.
Put the center bearing in place, put the nuts on the captive bolts.
Lightly tighten.
Then move the center bearing toward the motor, forgot the exact measurement, something around 3mm, then tighten completely.
The way I look for a misalignment in the guibo to flange, is to tighten all the bolts and nuts until there is about 1mm distance from the guibo to the flange.
Then while you are under a properly supported car, rotate the driveshaft and look for ANY flexing or change in that 1mm gap. If there is, then make the adjustments so when you rotate the drive shaft, there is NO change in that distance. Look top and bottom and side to side.
Story time - in Pikachu 1, I had a constant problem with her eating guibos. The first one failed while at 02 Fest East in Lime Rock, CT. Paul Wegweiser spent the whole day at the show trying to fix the car. We could not find a spare among 100+ cars. So we buttoned it up, drove it a few miles to Lawrence Charlemagnes house and in 15 minutes, Lawrence had a new one on and I was on my way back to Maryland.
The problem I had that took me awhile to find was a misalignment side to side. I fixed the top to bottom alignment problem but was failing to see the side to side misalignment.
Much to CD's chagrin, I put the bolts in the same direction. They are easier to get in that way and if one does back out, it stays away from the transmission case. I do only tighten the nuts, not the bolts.
1972 2000tii Touring #3422489
FAQ member #5
Bill, the reason the BMW service manual wants those bolts to be installed in that particular way - direction wise - is so that, when tightening the hardware, you are not putting a twisting/rotational force up against the metal sleeves that are imbeaded within the rubber of the guibo.
This is the same reason why the instructions say to not turn the bolt heads. That said, I know what you mean about the clearance issue.... and you're right on the money about checking for the alignment of the trans. output flange and the front flange of the driveshaft. This alignment is critical, and may require raising the transmission and/or lowering the center support bearing to achieve the correct alignment when using the longer five speed transmissions in a 2002.
Leave metal band on guibo while tightening nuts
only tighten NUTS while holding bolt head
alternate bolts so Nut is against metal flanges
use only BMW Special high-strength bolts
always use NEW self locking BMW nuts
only tighten Guibo nuts after aligning drive shaft
flange to trans flange - rotate slowly by hand to watch
for any run-out between flanges which will twist Guibo -
you will also hear a squeak if Guibo is being stressed
indicating out-of-alignment.
Leave drive shaft center spline nut loose and allow
drive shaft to extend or compress during Guibo tightening,
and center bearing "Pre-Loading" / tightening. THEN
tighten drive shaft spline nut last. Nothing should spin out
of alignment, or be stressed or under tension when fitting.
Except the center bearing rubber mount by 2 mm towards the motor when it's tightened.
BUY A BMW FACTORY BLUE BINDER REPAIR MANUAL-
A COPY OF THE 320i manual will work also -
it's the same sheit. BUY A MANUAL ! GO TO EBAY
