fog light switch wiring
Thought I remember seeing a pic of back end of a fog light switch, and which connections are which. Can't seem to find on the forum. Anybody?
which terminal--one terminal holds the wire that goes to the power source--suggest wiring through a source that goes dead with the ignition off so you don't accidentally leave the fog lights on, while the other terminal connects to the load--in this case the fog lights, through a relay. This will trigger the relay points to close when the switch is turned on. The relay's power supply should be a heavy gauge wire that you can connect directly to the battery's + terminal with an in-line fuse, or through one of the existing 16 amp fuses (cigarette lighter fuse is a good choice).
IIRC there's a third terminal on the factory pushbutton switch; that's for illumination, and should be wired to one of the instrument or control illumination bulbs--the easiest to reach is the heater control bulbs' terminal. Once you've isolated this terminal, the other two don't matter which wire goes where.
cheers
