Anti Freeze leaking....
Goudey
Have not run my 76 2002 since June. Just noticed a puddle of antifreeze under the engine ( not the radiator) and the #3 header pipe is wet with it as it seems to be coming from the stud or flange area of the #3 header.
Would this be a likely head gasket problem or just leaking exhaust flange gasket?
Have had a slow rise in temp after running engine for more than 30 minutes at 50mph.....changed thermostat, checked all hoses and radiator and coolant quantity stays up....checked timing etc. Could not account for the rise in temp almost but never into the red....
Any help is appreciated.
Richard
noticed a puddle of antifreeze under the engine ( not the radiator) and the #3 header pipe is wet with it as it seems to be coming from the stud or flange area of the #3 header. Would this be a likely head gasket problem or just leaking exhaust flange gasket?
Any help is appreciated. Richard
You answered your own question. If you are leaking coolant, that probably accounts for your temperature rise. Sight unseen, the headgasket is my first guess. Exhaust flange gasket has nothing to do with coolant containment nor am I am that stud contains coolant or even contacts it. There is the possibility your coolant passages are terribly corroded to the point where area around stud is leaking. That would be very unusual and you indicated using Antifreeze which deters such things.
