how do you match the distributer cap wires with the spark?
turboninja22
# 1 cylinder is at the front of the car - next to the fan blades,
# 4 at the back next to the distributor,
and you'll need a timing light because you'll never time
the ignition correctly without one.
the above advise also applies.
'64 R27 250cc #383851 18,000m
I would like to add that the distributor has a line scribed in it for #1. When the cap is off you can see it in the aluminum housing. The rotor should point at this mark at TDC for #1. The distributor rotates clockwise (I think, better check by hitting the starter and watching it). The next hole would be the next number in the firing order, #3.
I first owned a 2002 in 1975.
