Hey Beammer, your waterpump pulley?
the boss with a socket and 3lb hammer. The good news is the pulleys lined up, the bad the pump got wanked in the heat of the moment. Not one of my proudest moments, but now I know what to look for when the new pump arrives Friday. It's the first thing to be installed Friday afternoon, I will report back. Don
Don
I hope you removed the pump and blocked the impeller so whey you pounded on it the force went thru the shaft to the block and not thru the shaft then thru the bearings to the housing. Bearings can be "brinnelled" with flat spots when impacted axially like this.
new pump to be delivered tomorrow. I still have my mechanic's learners permit.
My real mechanic friend just dropped by, took a BFS (large stick) wacked the impeller a few times, it loosened up a bit, still not acceptable. Don
Don
the pump arrived last Friday. It was like I opened the same box from the same company. Two different suppliers, BavAuto and AZautohaus (sorry-not the dealer, $264.10 from dealer), identical pump, identical misalignment. It will be worked on Saturday, it's the only thing holding up the re-install of the motor.
Don
we again adjusted the pump using a better method although still using a BFH. The pump spins freely and the pulleys are aligned. Don
Don
