quick Q: Does the tii master cylinder use the same pipes...
mtriple
I recently replaced my 2002 m/c with a Tii m/c and it's a direct swap.
If you're changing the booster too, that's another story,as Pete said.
The Tii booster is longer. Why not keep the stock booster? Airbox or carbs in the way?
71, flat black
Beat to fit, paint to match.
Do what you love and you'll never work a day in your life.
"Some people spend a lifetime wondering if they made a difference, Marines don't have that problem" - Ronald Reagan
Mostly -
I just did this. I was able to tweak the lines for the right side and the rear to fit. It's the left front that is the toughest. The shortest line (left side, closest to the booster) no longer fit at all. I was able to bend the "old" line that went to the left front part of the M/C to fit the rear position, but it is tight.
I bought a new 400 mm line to go from the front left side to the hose on the wheel. It's a bit long, but that's easier to work with than too short. Got all of that installed yesterday, and I'm going to try and bleed the system today.
Finally - do a search for the brake booster circlip. I was having problems with "the circlip" on the back part of the booster. I did a search and found this thread:
http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,287555/highlight,brake+booster/
I bought the E21 clip, and had it installed in under 5 minutes.
Hope that helps.
Ken
FAQ Member # 2616
-- My wife.
And one more thing - you do realize that the Tii used a smaller battery? Once you get all of this together (tii booster and m/c), you will lose about 2" or 3" of space. The Tii M/C is about an inch shorter than the standard 02, but the I've heard people say that they can still shoehorn the normal battery in there. It looked to tight to me, so I'm using this an an opportunity to do the trunk relo with mine.
One more thing to think about before you get started.
Ken
FAQ Member # 2616
-- My wife.
