door locks
boldtu
Had my 71' for about two weeks now and the driver's door lock has been acting up. it opens fine, but when I try to lock it it gets stuck in lock. twice now I have to take the door panel off and place the locking piece at the end of the cylinder back into place. any ideas where I can get a replacement or fix this in any way.
thanks
key--if there's wear on the mechanism, it's fairly easy to turn the key past the lever, then it jams and you have to dismantle the door to retrieve the key (as you've found out).
If it isn't evident, e-mail me offline and I'll send you a fixit writeup from the 1976 BMWCCA Tech Tips book. I think it describes your problem.
e-mail in the past day or so. Will do so tonite after I vote!
FYI, when you e-mail someone thru the FAQ board, it automatically sends a copy to your own e-mail as well as the receipients.
