distributor number
norma
My 73 Auto had a very similar within 25 VIN. It also had a "JFUD4" 0 231 168 023. All of this information can be found on the outside of the distributor housing.
But that is not your real question, since there are any number of distributors that will fit and work with any M10 engine, including yours. The real question is the orientation of your points. There are only two different styles regardless of distributor number. It all depends on the orientation of your points. IF your distributor is a JFUD 4 then you want the 1847 Petronix.
See: http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,311832/
Good luck with that car. I miss mine very much.
Well, I tried to check the dizzy. Can't see the number very well. Looks like 0231215071. It looks like it's marked JFUR4. They're both pretty worn. It's with the black coil. Does that make sense? The points are forward. I'm thinking I need the Petronix 1847 but just want to make sure. According to Haynes, JFUR4 is what it should be if it's stock. Any more thoughts before I do it?
I am assuming when you say "worn" you are describing the imprinted numbers and not the distributor. The Pat Allen provided a reference chart for distributors. http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,286931/ I am not sure this is all that helpful regarding points placement and cannot tell if we are referring to the same concept when describing "forward" points since later distributors even rotated in a different direction AND different points plates/platforms can be swapped into different distributor bodies. Bottom line: you have a 50% chance of getting the right part. The difference will be obvious when you look at the parts. Ask the vendor about the off chance you order or receive the wrong part.
Good luck
