Always in gear? Manual Trans
tbernsen
Background:
I recently bought my 2002. The car was not in running condition when I bought it. She had a leaky gas tank and seized brakes (front still seized). The car hadn't been started since the Clinton era, but started and idled with a battery recharge and a some carb tuning.
Question:
Got the rear in the air to check the transmission. With the car in neutral, I started it. When the clutch was let out, the rear wheels turned in forward motion. The rotation was slow and was able to be stopped by hand.
I proceeded to go through all the gears 1-2-3-4-R, with no problems. Any ideas?
Tyler
1970 BMW 2002
1983 Husqvarna 125XC
1997 Subaru Impreza OBS (daily)
I might be totally off on this, but it might be just friction or somethin in the drivetrain rotating it. When I bought my bike I took it the mechanic. when he started it up it was on the center stand so the back wheel was off the ground it, was in neutral, and the wheel was slowly spinning, but you could stop it with your hand. any way the mechanic said it was friction.
as I said it might be somthing different, but I hope this helps.
72' tii waiting restoration
83' R80ST
Very possible. I've noticed motorcycles doing this on a stand too. Just wasn't expecting to see it with a car.
Yes, both wheels off the ground, open diff.
Tyler
1970 BMW 2002
yeah happens quite often, you see it more often with auto transmissions though
holy negative camber batman!!!
02 Golf Yellow cruising the border of NSW/VIC!
tii pistons, 293, double valve springs, 40mm DCOE's, sump baffle, sway bars, lowered, 5spd, big brakes, 3pc wheels, bucket seats. Approx 150+hp
