Really Stupid Question but I need to know
justinevert
Ok, I maybe killing a dead kitten here but, I am really concerned that I may have already screwed up big.
Is there a difference between the stud bolts for the intake side vs. the stub bolts for the exhaust side? It seemed that one was heavier than the other and one turned in tighter than the other.
Even more concerning is that there are two different part numbers.
Tell me I am not imagining things.
Thank you in advance!
Justin
The question is not that we broke a few rules or took certain liberties with our female guests.
We did ;)
Charlie don't surf!!
as long as the diameter and thread pitch matches the holes, and they are not too short your good. I believe the only difference is the length. Stock exhaust manifold is thicker than a intake at the flanges. I got my exhaust studs from AutoZone. Don't forget to loctite the exhaust studs and use copper nust. I've got misc spare studs in my stash but I'll be away for a week. Feel free to call me.
I had the same thought when replacing my exhaust studs. I bought both sets from Maximillian and believe the (2) are different colors. I think the threads are the same - but am not sure.
As long as they thread smoothly into the head you should be fine. Ditto on the loctite and copper nuts (for the exhaust).
a compatible (in length and thread/pitch) exhaust stud from a Saturn (IIRC) that has an Allen hex socket in one end that allows you to install it into the head much more easily--and hold it in place when you're trying to back out the nut next time you remove the manifold.
Probably easier to find locally than the OEM studs...
yes I recall that thread too but didn't follow up as I already had my new studs. OEMs are available at dealer but may have to be ordered, allow a couple of days to get in hand
Bob
BMWCCA #4844 (#297 of The 308)
1974 2002 Sahara, MM 2400 Rally engine, MM 5 speed and conversion
1976 2002A Anthracite parts car
1991 525i AlpinweiB II
2002 330ci AlpinweiB III
2007 530xiT Titanium Silver
Thanks guys, I was really worried for a moment
I decided to double check the bolt length, they are both the same as well as fitting both intake and exhaust manifolds, looks like I have thread to spare.
Again, thanks!
Justin
We did ;)
