Which direction do you mount the driveshaft center bearing?
punchesdfw
with both ends of the drive shaft tightened, and the center bearing
mount up, and the 2-bolts loose -
'pre- tension' the center mount to the front 2-3 mm's and then tighten the 2
mount bolts.
as you can see from the diagram - the 'cup' faces the trans
alignment of the shaft is important !
'64 R27 250cc #383851 18,000m
