Grounding locations
doug73cs
My battery is under the rear seat and is grounded to the arm rest support bracket - bare metal contact and tight bolt. Are there differences in the strength of the ground in different locations? I still have intermittent starting issues and have eliminated the starter and solenoid (had it checked/serviced), ignition switch (new), battery disconnect, battery and alternator as causes which leaves..... ground ???
It's a 73CS.
If we learn from our mistakes does that mean I have to make them all?
73 CS Polaris
76 2002a Sahara
Would the rear seatbelt bolt be a good point to ground to - clean off the paint and sound deadener - all clean metal connections? Rear seat is deleted.
My ground strap from starter to chassis is connected.
Thanks.
76 Sahara 2002
73 CS Polaris
84 Tucker Snocat!!!
The bracket is attached to the tub by 4 little tack welds and who knows what preparation was done at the factory. Pretty optimistic on my part as the primary ground for the whole car but it was so easy!
73 CS Polaris
76 2002a Sahara
