Starter removal/install tips for novice
EngineerTim
So thanks to the diagnostic input of quite a few of you I believe I've narrowed my hard starting condition to the starter and have the smaller Bosch replacement on the way. Tips on removing the old football-sized starter? Do I need to remove anything major to pull it out the top? Just 2 bolts to trans + bracket bolts? Tips on connecting up the new one?
Thanks in advance.
Patience, mostly...
The nut is really hard to get lined up on the underside.
Unhook the negative battery post first.
It's not particularly hard...
http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,299382/highlight,starter/
Do yourself a favor and do the cap head bolt that is suggested, that makes the next removal a piece of cake.
1972 2000tii Touring #3422489
FAQ member #5
Get a cheap 19mm (?) socket it and cut it down to the depth of the bolt head.
That should allow you to use a 6" extension and ratchet drive. All this assumes the same set up as the m30 in my CS.
76 Sahara 2002
73 CS Polaris
84 Tucker Snocat!!!
