Transmission Mount Interchange
rtheriaque
Folks,
I was given a tranny mount off another BMW from the same vintage (early 70's). All I know is it's one of an identical pair off this particular transmission. The number on it is 1 131 664. It looks to be about the right size. Think this will work?
Thanks,
Rob Theriaque
~Rob
'73 2002 Warmbold Rally Car Imitator
'89 325i Time Capsule
Sorry, I guess I rely on my signature too much. My car is a '73 2002, 4 speed.
I don't have too much to go on about the tranny this came off. About all I know is it's the same era (early 70's) and the transmission had a dual mount carrier (as opposed to the 2002's single mount carrier). The gentleman owns a '72 3.0CS, but I don't believe this transmission came from it.
~Rob
The part number you listed is an earlier part number for a trans mount for an E46 3 series, a E39 5 series or a Euro 740i with manual transmission. If it works dimensionally, you should be ok, but it may be easier to buy a 23 71 1 246 004 and drill the hole in the plate out a little for the larger lower stud.
The 004 mount, although sturdier than the original, is no longer inexpensive however.
Yikes! I wonder if it's a similar situation to the 320i mounts in 2002's where the newer mount fits the older style and works better...
Great grab, regardless, and thanks! I'll let everybody know how the swap goes.
~Rob
