Clutch pedal "click"
moloko
On a long road trip today I felt and heard my clutch pedal click when letting it out. It happens almost every time I let the pedal up, but not as much if I push the pedal a little to the left when doing it. The previous owner said he had a clutch put in right before I bought it and it never did this until today. Could this just be the linkage being a little funky, or is it a sign of something more serious?
It's on a 1975.
before getting drasticwith a wrench, you should pull out the vac and clean out that pedal box. then with a flashlight get in there and try to reproduce the clicking by pushing the clutch by hand. that is were I might start a diagnosis as a lot of dirt can easily collect in there IMHO.
'76 2002 anthrazitgrau 'Eli' the Chancellor
'87 325i delphin 'Chandler'
If the click isn't in the pedal assembly, it is fairly common to develop a click between the pushrod and clutch lever. That's a pretty easy fix: work a little grease between the pushrod and clutch arm and twist the pushrod a little so that it contacts the arm with a different surface.
Matthew Cervi
'71 Bavaria
'18 M2
Could be a loose pivot bolt or pushrod adjuster bolt. If your master cylinder is not too old, inspect the pivot link at the pedal for cracks. I've lost two of those, and a forum search reveals that this part fails fairly frequently if it is the newer aluminum pivot link. The old ones were steel and seem to last much better.
Jerry
no bimmer, for now
This was hapening with my clutch and i thought it was a clutch spline catching because the pushrod was going in too much.
on my 76 and i think on your car aswell we can not adjust the pushrod length on the slave. also i prefer to have my clutch and brake pedal at equal levels when not depressed.
I decided that the clutch was engaging too much so i tied a small piece of metal pipe behind the clutch pedal so that it could not be depressed all the way to the floor.
the pipe is about 1/2in and it did the trick.
If there is a better way....... i believe its removing the pushrod and grinding it down allitle? Im sure someone will chime in.
Im new at these things still so my method is prob. super rigged well see with the next responses from some more 02 gurus...... ;) i love this site!
For those who are canny enough to search next time-
the spring on the clutch pedal can break, and the parts will click as they
slide against each other.
One more thing to look for...
  • 9 years later...
Amazing.. there seems to be an answer for everything... hopefully. As a couple searches revealed, my new rebuild has developed this annoying metallic "click" when I release the clutch pedal. Not when I depress it, but when I release.
I have the TO greased well and the round medal pivot point inside the bell housing (with a new rubber grommet) also. But seems like people are pretty sure it is where the metal slave rod end inserts into the fork hole. I do not believe I have any lube there, so that is my first fix when I get back to the car. Also, as indicated I will rotate the slave rod.
Any other suggestions... I am certain it is not in the pedal box or assembly.
Randy
1975 - 2366762 Born 7/75
See the whole restoration at:
I had that symptom once.  I tracked it to the pressure plate.  One of the (spring) tynes/fingers (not sure what they are called)  was clicking on release.  Drove me nuts.  Finally swapped out with a new clutch kit.
Hopefully yours is a different problem.  While you're under the car :) have someone push the clutch pedal.  If the sound emanates from the bell-housing I'd bet that's the issue.
I'm not sure if it's a catastrophic problem.  Some of our race car owner/members might have an answer.
Good luck.
73 Inka Tii #2762958
My car (1967) had a terrible, almost cracking type of sound whenever I released the clutch pedal. I ended up putting some lithium on the return spring ends (linkage in the engine bay) and that cured it. It was just a rusty spring creaking along the holes it was connected to as it changed tension.
