Help! Compression Ratio of S14 Shortblock with E30 M10 Head?
Digby
I have what amounts to and S14 shortblock and have intentions of installing it with an E30 M10 head.
Has anyone tried something similar? If so, do you have any idea of what the compression ratio turned out to be?
Thanks.
Digby
1984 318i-Drivable
1984 318i-Parts car with off-road title
Hi Digby. I've done something similar, although not exactly what you are looking at I don't think. The primary difference is that it sounds like you want to use the stock S14 pistons. The challenge with this is that they are designed for a 4-valve-per cylinder head, not a 2-valve like the E12 heads. As such, you'll likely run into clearance issues and the shape is just not optimized. That said, I know it has been done using a thicker head gasket, but obviously this would reduce your compression ratio. The person who I know that did this was running the motor with a turbo, so low compression makes more sense for this application.
Personally, I ended up getting custom pistons from Ireland which had the S14 bore but were designed for the E12 head. I also used the S14 head-gasket since obviously the M10 head gasket is designed for a much smaller bore and also doesn't have some of the same coolant holes as the S14 one.
Let me know if I can help you with any info, I learned a few little tidbits along the way to do with pairing the E12 head to the S14 block. Also, if you search the archives under "stroker" you'll likely find some good info. Good luck.
Grover,
I much appreciate your insight. And going to custom pistons designed for the E30 head is undoubtedly the better way to go.
As I get further into my project I'm sure I will be getting back to you with questions about installing an M10 head on an S14 block.
Digby Willard
1984 318i-Drivable
  • 4 weeks later...
Grover,
Couple-three questions about your S14/E12 engine setup.
1. What compression ratio did you specify for the custom pistons you bought from Ireland Engineering?
2. What octane gasoline do you use in the engine?
3. Did you use stock M10 rods, S14 rods, or custom rods from Ireland Engineering or similar?
Thanks.
Digby
1984 318i-Drivable
