I'm proud of the tii- survived her first long rally
Jared
This past weekend th 72 tii completed the first long trip I have done. Roughly about 950 miles with elevation changes from sea level to 10000ft ++ in the high sierras.
Our loop started in Santa Cruz down to Big Sur, across the mountains and central valley to the Sierras, over to the eastern Sierras and back through Yosemite. She ran great though, some lack of power at the high elevations and a little trouble idling at over 10000ft up at the Ancient Bristlecone Pine tree forest, but that is expected. No temp issues while being pushed hard for extended periods and over the high passes. My two friends both had car issues, my friend's VW Gti died (ignition issues) as we were headed back to Yosemite and he is still stuck in Bishop waiting for it to be repaired, and my friend's 89 E30 325i sprung a coolant leak at the higher elevations. The tii had no such troubles :)
Jared
www.DrivingWhileAwesome.com
'72 tii
'00 Tacoma PreRunner
your friend with the '89 E30 probably never had the BMW COOLENT SYSTEM RECALL
performed ?! involves replaceing heater hoses,
radiator cap, and other junk to prevent cooling system
failures due to too high pressure build-up -
it can cause heater core blow-out as well.
just for your buddy when he returns:
Campaign Number: 93V015000 Date: 1993-Feb-01
Component: Visibility: Defroster/defogger System: Windshield: Heater Core
Defect Summary: THE MALFUNCTION OR FAILURE OF A COOLANT SYSTEM COMPONENT RESULTS IN SIGNIFICANTLY INCREASED COOLANT TEMPERATURE AND A RESULTING INCREASE IN SYSTEM PRESSURE.
Consequence Summary: VEHICLES OPERATED UNDER THIS INCREASED COOLING SYSTEMPRESSURE CONDITION CAN SUFFER DAMAGE OR FAILURE OF PARTS OF THE COOLING SYSTEMSUCH AS (1) LEAKAGE FROM A COOLANT HOSE, (2) LEAKAGE OF THE RADIATOR OREXPANSION TANK, (3) DISCONNECTION OF A HOSE FROM A PIPE OR A FITTING, AND (4)CRACKS IN THE HEATER CORE END PIECE RESULTING IN COOLANT LEAKAGE. IN SOME CASES,BOILING COOLANT CAN CONTACT THE LOWER RIGHT LEG OF THE DRIVER RESULTING INBURNS. ALSO, ESCAPING COOLANT IN THE PASSENGER COMPARTMENT CAN CAUSE VAPORFOGGING OF THE INTERIOR SURFACE OF THE WINDOWS, REDUCING DRIVER VISIBILITY.
Corrective Summary: DEALERS WILL INSTALL A THERMOSTATIC BYPASS VALVE IN THE ENGINE COMPARTMENT TO CONTROL COOLANT TEMPERATURE IN THE HEATER CORE. ALSO, A NEW DESIGN RADIATOR CAP WILL BE INSTALLED, TO CONTROL PRESSURE AND PROVIDE GREATER COOLANT OVERFLOW IN THE EVENT OF OVERHEATING.
Good Luck to him
how was your tii injection fuel/air mixtures during the higher altitude
motoring ?
'64 R27 250cc #383851 18,000m
It was good to meet you too, your guys team did an awesome job.
Yes, we will be at Thunderhill, we will probable be running an E30 for that race because the 944 isn't running anymore.
Look forward to seeing you there!
Jared
'72 tii
