Dumb question.
Im trying to replace my alternator belt. But can't get it on. No luck anyway I try, is there a trick or did I get the wrong size. What is the stock size for a 76 2002 with no mods.
lower. Seems there are two different belt sizes that'll work--some on some cars, some on others--either a 9.1 x 875mm or 9.1 x 900mm.
I've had the same problem. Sometimes I can get it to pop on by running around the fan and crankshaft pulley and as far as it'll go on the alt pulley, then bumping the starter. That'll pull it the rest of the way.
