Mikesmalaga72
2002 turbo exhaust system.
4 posts / 1184 viewsLast Reply
No, it won't.
What i have done is got a 2foot length of 58mm (the diameter of the turbo pipe) pipe flared the end and got a three bolt flange.
I have then cut off the the single pipe from the down pipe and replaced it with the thicker pipe. The new bit of pipe has to be longer than the original because the turbo centre silencer is shorter than the stock one. This way you don't mess around and cut up your expensive new turbo pipe and it will all fit if you upgrade your manifold and down pipe too.
I'll take some pics tomorrow for you.
A transitional/adapter pipe is the way to go. I've got a turbo exhaust on my touring, and I believe it's 2 1/8 inch if I remember correctly...
