Sign in to follow this
ryanOC
cold start valve for tii is busted
3 posts / 806 viewsLast Reply
well, seems to be spraying a ton when ignition is on
is it bad? or is there a chance it has to do with wiring (eh??)
anyone know how much $ these go for?
Does it stop when you unplug it? Or is it leeking from the tank pump pressure. if it is only when the connected, you will need to check the wiring on timer box. The timer boxes often go bad but can typically be easily repaired if you own a soldering iron and a bit of wire.
KC
pretty sure i had it both plugged and unplugged, but i'll look again
prices for these online look to be ~$120
gee whiz!
