ascottbar
Rear Suspension Question
3 posts / 1202 viewsLast Reply
I have a 76 02 that has lowering springs and I need to replace the damper rings (#4 in the picture). They come in either 28 or 37mm. Which size would be appropriate for the lowered car? Thanks!
What size is on the car now?
Over here 2 dot 28mm are usually fitted from the factory.3 dot 37mm would raise the rear of the car by 9mm.
I don't know if 1 dot pads are still available, but they are approx 19mm thick and would lower the rear by 9mm compared to the 2 dot pads
Depends how low you want the car to sit
.... as David just said -
how many DOT(s) rubber is in there now? and how much lower do
you need?
order from any BMW dealer or place an ad free
over in the PARTS WANTED section
top rubber ring
33.53.3.450.106 37 mm 3-dots
33.53.3.450.108 33 mm 2-dots
33.53.3.459.107 28 mm 1-dot
