Kamper
M10 block sacrificial anode
3 posts / 1173 viewsLast Reply
Did the M10 block intially have a sacrificial zinc anode inside the cooling passages? If so, was it attached to a drain plug? Are zincs still available? Thanks in advance, Kamper
Did the M10 block intially have a sacrificial zinc anode inside the cooling passages? - no - and not anywhere on the body either !
BUILT IN OBSOLESENCE
No, you were supposed to use coolant.
Just like all other aluminum/iron motors...
