Sign in to follow this
steved
Bushing Replacement List
4 posts / 1362 viewsLast Reply
I've been reading through previous postings and looking through the Ireland Engineering parts list and I think I've assembled a list of all of the bushings I need to replace for the front and rear of my car. Does this list seem complete:
Front
control arm bushings (both ends)
lower strut rod bushing
idler arm bushings
Rear
Trailing arm bushings
Diff hanger bushings
Subframe mounts
Thanks
Yup looks good. The only other bushings to consider would be the sway bar bushings.
I believe that most of the ones you mentioned come in the front and rear bushing replacements sets from Ireland.
I just did this and it's a pretty big "might as well" project. Might as well replace the sway bars, might as well replace springs and shocks, might as well install an LSD, might as well take out the whole subframe and rehab it.
Don't know if any of these things are on your mind, but if they need doing, now is the time.
Thanks. Yes, springs and shocks are on my list, too. So is everything else, but the line will have to be drawn somewhere.
Good luck drawing the line. I tried that and ended up with a total rehab...expensive, but I love it and can't wait to drive her!
