merek22
water outlet
2 posts / 649 viewsLast Reply
If you use the 320 water neck or cut and JB weld the 02 neck, then you don't need to replace the omited nipple. The hose you delete was for warming the manifold to prevent fuel icing up on cold days (or does it cool it on really hot days???) anyway its not needed. You may want to fit the steel pipe that goes from the water pump to the heater outlet (also from a 320 or Tii) or just add a section of rubber hose as the WP no longer goes to the manifold either - see pic.
Beaner7102
