Sign in to follow this
Inka114
Need frame measurement data
7 posts / 1571 viewsLast Reply
Does anyone have the frame measurement data/diagrams from the factory '02 manual in electronic form?
I need to take some measurements to see whether my subframes have been tweaked out of position. I have a paper manual lined up to borrow, but I can't get at it this weekend, and I have an opportunity to get the car in for paintwork right away. I'd like to know before we start how much pulling and stretching will be needed...
Thanks,
I should have been more specific - thanks for this info - I need front data most, although I will check rear too:
Thanks,
YOUR FRONT IS T.R.A.S.H.
you don't need to measure that .
Agreed. The crossmember and everything attached will be replaced. I need to measure whether the subframes that it attaches to are still in the original location.
Thanks,
your "subframe" is your "cross member"
here are the specs. and check points for the "body"
that the other "bits" bolt onto .
Danke sehr! c.d., you da man!
I apologize for the confusational terminology - I hadn't seen the manual in many moons, and I didn't remember which term they used for which.
Now to lie under the car for a bit with the tape measure...
