Sign in to follow this
uxoman
Coil Over Suspension
2 posts / 964 viewsLast Reply
Is anyone familar with this set-up? Brand is unknown on the fronts but the rears are carrera. The lower spring perch on this set-up is aluminum. Not sure how it mounts to the strut tube. Any one know? The seller has no info on these. He thinks the lower aluminum perch just sits on the shorten strut tube. Does this sound right? All the kits I've seen this perch is welded on. Any thoughts? His email reads:
Race suspension coil-over kit. Lowers your car and improves performance with a firm ride.
Bilstein front struts with matching 275 lb rated Blue Coil springs.
Carrera rear shocks with matching 325 lb. rated Blue Coil springs.
Comes with adjustable aluminum spring perches for raising or lowering ride height and firmness.
Huh.
Looks like a prescription for oversteer to me from the spring rates,
but it otherwise looks like something someone made up themselves...
