eastsidebimmer
Bmw 2002 Badges HELP
8 posts / 1463 viewsLast Reply
Hi all
I Know this may seem a silly question but will any BMW badges from any BMW car fit on a 1975 2002 BMW. and if not what are the sizes of the 2002 BMW badges . i need sizes for the front badge and rear badge
Thanks All
Adam
both the hood and trunk roundel are the same on all years...you are aware there is a slight difference between the hood and trunk though
YES - the hood and trunk lid roundels
are larger then the
roundel between the lic plate - tail light.
are larger then the roundel between the lic plate - tail light.
it seems people are trying to confuse you...you clearly stated you have a 75...not a roundie...as noted earlier, all roundels for the trunk and hood are the same size...
Same Diameter, maybe.... but not the same badge.
A Square rear badge had a curved bottom edge to match the curve of the decklid. The front badge is flatter and thinner since the hood doesn't curve nearly as much.
They're 2 seperate badges. One will not fit in the other's location.
the Square rear badge had a curved bottom edge to match the curve of the decklid. The front badge is flatter and thinner since the hood doesn't curve nearly as much.
