Is there a way to pressure test fule lines?
I want to know if there is a way to hook up an air compreesor to test for leaks or blockages in the fule lines. Also will the gas tank out of a 70 fit into a 75?
Thank you
Andy Rattley
you could get some barbed/pipe fittings that you could seal off on one end with a PSI guage and then put a bicycle-type valve on the other end. Then run the compressor up to 2-4x your maximum expected fuel pressure, pump up the line, and wait. If it holds the pressure, youre set! And yah, the fuel tanks should be interchangable through the years (although sender assemblies may not be) Hope this helps!
-Rob
