quarter window reassembly order.
BLUNT
i searched some but didnt find exactly all the info i need. i assume it goes like this.....
install b pillar seal and new aluminum b pillar trim,
install new horizontal aluminum trim on base of window ledge--(does this rivet in or screw in>? i forgot)
install new 1/4 window rubber seal. any tips on installing these? ive sold hundreds but have yet to install any myself.
thanks
www.BluntTech.com
FAQ Supporting Vendor
 Sales@BluntTech.com
the trim pieces are installed with aluminum rivets. i will be doing this in the near future myself. i've been considering using a mastic-like sealer between the aluminum trim and sheetmetal just to keep moisture away, as i've seen many cars with rust seeping out from under there.
i do recall when i installed new 1/4 gaskets a decade ago that i had a heck of a time inserting it in the groove. as i recall, it was very unpleasant.
& 1 special alfa
Nov or Dec Roundel. If you don't have, drop me an e-mail and I"ll send you an electronic copy. The real trick is supporting the window while you install it so it doens't slip out of your hands and shatter on the floor...
