I have no power to #7-#11 fuses
Ryan_71-02
Anyone ever had this problem before or know the wiring well enough to have a common connection point for these fuses? Its my '75, former automatic now 5spd with the AC removed. The struggle continues... and I just thought the blower motor might be bad.... Gee, I feel so lucky to have no juice to five fuses as apposed to pulling the damn heater box... Whatever ideas you've got, let me know...
Ryan
Off to wiring schematic hell....
I would check under the fuse box to see what is going on there (after disconnecting the ground from the battery!). I just looked at a spare fuse box I have and I don't really see anything in common on those, but it may be different on yours. Or a mouse chewed through several cables.
Matthew Cervi
'71 Bavaria
'18 M2
fuses deal with lights--7 & 8 are tail and parking lights left and right, 9 & 10 are low beams and 11 is for high beams. Odd that all should be inopoerative at the same time, as of those, 9-11 are routed thru the ignition, but 7 & 8 are hot all the time, so it shouldn't be a common feed problem.
Let us know what you find...
cheers
