accel pump leak on weber
bmdubracing
Hi everybody, I decided to remove my Weber Carb to get to my bmw 2002 starter. The car has a single 2 barrel carb but, the car sat for 4 years in a persons yard. The carb works great but the accel pump is broken. It leaks whenever you push on gas. I think its a seal issue but i'm not sure, I haven't seen any replacement breakdown parts for the weber carb. I will try to get the number for the carb model but right now all I know is that it fits the stock intake manifold.
If anybody knows anything about where to get parts or if the seal is the problem please let me know. Thanks for your time
"the usual sources" (Pierce Manfolds was mentioned, there are others, perhaps local to you, it's a common part) separately from the entire carb overhaul kit. Easy to replace, too. My original diaphragm finally gave up the ghost last summer after 27 years!
Pierce Manifolds, Bavarian Autosport, probably 2002 haus, Depending on where you are located try Greenfield Imported Auto Parts in Greenfield, MA 1-413-774-2819 they are great but I'm not sure about shipping. I've always picked up my stuff from them.
Part should cost you under $20 shipped to you.
E36
