Those of you planning to turbo and MS your 2002s..........
PSloan
Either that, or one from a Honda B series. How big do you want to go? 60ish mm is plenty. If your motor is having flow issues through the intake side, I think your intake manifold will be the real problem. I would recommend having made an intake similar to the old style "long" manifold, but with shorter fatter runners and a much larger plenum. A 70mm tb will help but, once your there, your turbo will likely be the restriction.
I crudely measured the diamiter, and it is 65mm. Im going to have to run an adapter plate for the 320 manifold. Im not sure how it would work with a 318 manifold. My plan is to run a garrett GT2860rs aka "The Disco Potato".
1974 Cinnabar M2: S14/320CR/391LSD/Turbo Exhaust/Turbo Radiator/323 Trailing Arms/Ground Control Coilovers
I will be running a Ford 5.0 HO TB. It is around 60mm. I made a simple adapter plate. The ford part has a spot for a IAC valve that will work with MS and also has the correct TPS. I think I got it off ebay for about $15
HTH,
Jake
1985 e28 w/LS1/t56 and a bit more...
1970 2002 w/ m42 swap
-Contact me for m42 mounts or e28 ls1 mounts-
www.classicdaily.net
Yeah I might be able to make one for you. Are you in a hurry to get it? Find a TB first. I think I could make you a plate over my Christmas break.
All you really need to make it is....a flat piece of aluminum, a drill, a few drill bits, a tap, a jig saw, a couple files, and some emmory strips(to smooth it out.
Jake
HTH,
Jake
Do you know what that TB came off of? I'd like to find myself one too...
Also what type of TPS is it?
E36
