Best Radiator for M20 Conversion
bavtech
HI Everyone....
I am doing a M20 Conversion in my 1969 2002 and was wondering what it the best radiator to use with the conversion.
I have read 323i but those are not easy to come up with.
What is everyone else using in there M20 swap??
Thanks
1969 BMW 2002 Turbo M20-Under Construction
1997 BMW 540i6
1989 BMW 535is
What are you guys using to mount the bottom of the radiator.
I picked up a brand new Behr Scirocco radiator for $45 thru my work. I see two stubs at the bottom. Should I use those or what is the best approach.
1997 BMW 540i6
1989 BMW 535is
here's what i did. i actually had to move them farther apart after this pic tho. cut a 1" length of box steel, drilled a hole straight thru, cut it in half diagonally, and used a large punch to make it concave so i could use the rubber donut spacer thingies too. took < an hour i think.
..and I also do not own a BMW 2002.
