racebmw
M3 Starter bracket
9 posts / 975 viewsLast Reply
I have purchased an E30 M3 starter for the racecar. The starter has the provision on the back for a bracket to connect the starter to the engine block. The new starter does not include this part. The ETK lists the part as "Starter Support Plate" p/n 12 41 1 308 480. Has anyone purchased this part and used it on an M10 block. I see no reason it shouldn't work but would like to before I buy one.
Thanks
Jeff
Dont need it. I bought it and never installed it. She starts up great. If you really want one I'll sell you mine for a few dollars ;)
I run solid motor mounts in the racecar so there is a lot of vibration. I think the bracket may help the starter motor last longer.
Jeff
Still don't think you will need it. The M3 start is significantly lighter. Otherwise if you are still concerned create a custom bracket. The stock one won't fit the M3 starter if I recall correctly.
you guys won't BELIEVE how much vibration there is on a race car...
Jeff, can you redrill the standard '02 one?
I need to do this swap, too- I'm almost #200 overweight...
so you can't redrill the stock one.
I will get the genuine one or build one.
You didn't look 200# overweight when I saw you at Seattle.....
J
That's because I didn't bring the car...
(is that funny? hmmm...)
