72BMW2002TII
my car crapped out on me.
5 posts / 704 viewsLast Reply
yeah-
if you can get to 'em,
remove the detent caps on the trans,
and then try to shift.
I bought a 5- speed that was 'jammed'-
somehow, the detent spring had jammed the ball,
and taking it apart and replacing the spring fixed it...
did it ever do this with the 4-speed ?
is it your clutch friction disc seized to the splines because of no, or inpropper spline lube on the clutch splines during a transplant ?
That would explain why the clutch is not releasing
or
do you have a hydraulics issue with the clutch master / slave ?
was thia after high temp - long duration driving period ?
is it 'better' when all is cold ?
or
cd, whay do you ask if this occurs after a long period of use? This sounds like a prob I just encountered with not being able to shift to the upper gears after prolonged use(R, 1, 3)....it comes and goes intermittantly...and only seems to happen when at a complete stop...do you have an idea of what's going on?
Thanks,
Brian
