Sign in to follow this
RacingAli
Rebuilding LSD questions...
4 posts / 892 viewsLast Reply
I want to rebuild my 320i 3:91 LSD. I am looking for parts, like shims clutches etc. And I am looking to add lock up % to it. Any suggestions?
which 04 do you add.
realoem lists only one 03 but it lists 3 different parts numbers for 04.
1.9mm, 2.00 mm and 2.10 mm.
I am looking at an e21 lsd.
is it one set of 3&4 give you 25% lock?
two sets of 3&4 give you 50% lock?
and three sets of 3&4 give you 75% lock?
And you have to add a set on each side so you order them in pairs?
I'm curious as to the answer to Tiger75's question regarding the use/mix of "parts 3 & 4" to vary the LSD lock-up too. How's that work? Is it as simple as combos of those parts and not more extensive mods?
