Sign in to follow this
38927
::Converting to Fuel injection?
3 posts / 732 viewsLast Reply
Hello,
I've had my 2002 for little bit now and
want to take on a turbo chargeing project;
Can anyone give me a complet parts list on what
to grab from an e30's m10?
All opinions welcomed.
My car is a 71 btw.
Thanks.
Ge the COMPLETE intake manifold and engine wiring harness. Be sure to get the airflow meter also. I don't know what type of ignition system you intend to run but whether you need it or not you should probably snag the distributor and ignition control module (bolted to firewall) Remove the DME (engine control module) above the glovebox as well as the idle speed control unit. You can use the in-tank fuel pump (pre-pump) and externally mounted high pressure fuel pump if you like. I had them both but opted to use the single in-tank high pressure fuel pump from an '89 325i.
Hello,
Check out these links on Megasquirt stuff:
www.finkbuilt.com
www.zeebuck.com
Both used Megasquirt (DIY EFI) systems alng with E30 M10 stuff. Seems to be the best option.
