Sign in to follow this
steve k.
we have more memory
31 posts / 4971 viewsLast Reply
The momory problem with the server has been resolved. We now have more RAm and hopefully enough to sustain the traffic.
steve k.
how much memory was it/is it now? just curious... ;)
1gb? That still seems small. I am used to my 2850s with 4gb of RAM :P
Anyway, create a bash script to nuke those log files once a week.
I can help you if you want.
What version of mysql we running? What does the my.cnf look like? You can streamline that... and I can also build you apache 2.2 rpm (assuming you use redhat) as well. It will really fly then. :)
the issue with logs is that fior some reason the setting for the slow.query one gets reset every time we reboot the box. A little strange. So it logs every query run without an index. There are lot of them.. All i want is queries that take more them 5 seconds. And those practically do not exist.
steve k.
Whats the /etc/my.cnf look like? Keep in mind that my.cnf does NOT get installed with mysql... so if you set something via mysql command line and restart the service or the box you will lose the setting.
Inside my.cnf... (among other things):
You could change the value of:
long_query_time=6 and slow queries will be greater than 6 seconds.
Also you can set the location:
log_slow_queries=/var/lib/mysql/slow-queries.log
Also when you do a "mysqladmin", it will tell you what places it is reading the my.cnf from by default.
What version of mysql are we running? 5.0.something ?? 5.0.26 is current.
I do the same thing with my logs but every hour actually! We get about 500,000 page churns a day so we need it. We also need 4 machines with 16 gigs of memory each because we are running an enterprise Java application. No PHP kiddies here ;)
Yea you need 16GB of ram just load JVM itself ... thats without any programs :)
PHP here. All I can say is LAMP rules. We are at 40-50 million searches a day on one of our products.
Dont get me wrong. I also use PHP, but mostly only for quick and dirty things and personal projects. I dont think I would like to build a large e-commerce site on PHP again after knowing Java really well.
I also find that PHP allows developers to be extremely slopping and write one-use only code. That being said, anyone can write bad code, I just find that PHP structure lends itself to that.
woot!!
the swap isn't even being touched!!
but.. there's 1 zombie!! AHHHHH.
Man, at my new job there's a solaris box with 1500day uptime.
Bind quit on it and I had to log in to see what happened. .booya.
woot!!
its holloween.. there's always one zombie!!
it was there just for a sec while I did the screen grab.
Steves controlling my.conf looks pretty groovy to me.
join_buffer_size=1M
key_buffer_size=50M
max_allowed_packet=128M
max_connections=500
max_connect_errors=10000
open_files_limit=65536
read_buffer_size=1M
sort_buffer_size=1M
table_cache=500
thread_cache_size=20
wait_timeout=200
long_query_time=5
Might be time to up the key_buffer_size since the new memory ..
sorry steve for exposing the guts.. its like letting someone look in your engine uninvited.
i'll quit
i don't know nuthin about any of that stuff. But I do know we need to decapitate or scramble the brains of that zombie, before we have more zombies.
