2 deg. Norburn & Miller fixed camber plates
Armond
I was lucky to find these localy, Can I simply slap them on w/o any major mods? Car has 15X7 rims, 5mm spacer,Eibachs all around and Billstein sport shocks. Thanks
73 Tii A4 BOD Oct. 13,1972
74 Tii BOD Nov. 16,1973
FAQ Member 1683
Mario Andretti
overs in the front, you're only going to get about - 0.5 degrees of camber. The top spring perch bangs into the inner fender.
FWIW, Ireland can bend the struts and get about -1.5 degrees negative with the stock spring perch.
John N
The guy I got it from says I'll get 2 deg tops. w/o mods. Oh well, better than nothing.
Steve, might just be the case but I may bring it to CJ this Saturday for him to have a look see.
FAQ Member 1683
Mario Andretti
