OK, Here's a dumb question for ya!
If one is planning to put in a Tii dist., Bosch Red-Coil and a MSD6a or crane would it not be best to put Bosch Platniums pugs in. Technically it's more electric that a mechanical system.
Your thoughts!
J.E.
Your thoughts!
J.E.
It's my understanding that plugs should be chosen based on two factors, heat and resistance. There are two ranges, both of heat and of resistance for a given type of plug, meaning you can have a high resistance (for high performance systems) and a low or high temperature. Just like you can have a high temperature plug with low or high resistance. The ignition system will probably give suggestions or maybe someone who understands this better will fill in the holes.
HTH,
TJW
E36
Your thoughts!
J.E.
I tried switching to the Bosch Platinums once at tune-up time. Didn't like 'em at all, made the car run poorly in comparison - so after I week I switched right back to the tried-n-true Bosch Supers. I have the MSD 6A, MSD Blaster 2 coil, & Tii Dist w/Pertronix. My experience - YMMV.
Where we goin’? … I’ll drive…
