Questions for those with Ireland sway bars
mikem
I have them front and rear with 2" drop springs. They seem to be the lowest point on the car but (in the rear) they are on the same line as the axle so I have had no clearence issues so far. I have an air dam that will scrape if I go to sharp on the driveways so I aviod that as a rule.
Drives like it is on rails.
75 2002: weber, ANSA, lowered, 14" wheels, new engine, new suspension, rust free & square.
I just happen to be measuring them last night. My front tow hooks are 5"from the ground and the front sways are 4.5" from the ground. So it would be save to assume it will be 1/2 inch lower than your tow hooks. I have the 22/22 and they make a big difference.
HIJACK!
Did you get your car back.
Cris
Proud member #113
The rides!
www.cardomain.com/ride/792851
www.cardomain.com/ride/792793
HIJACK!
Cris
Sure did! I had a long night friday so I didn't wake up for the swap meet. Planning to caravan with you guys to the Sigfest West in a few weeks. i need to redo my exhaust cause the Header flange is 3" off the ground, which is why I was doing the measuring.
Ray
73 Chamonix-S14 powered
Elefant Supply Apparel & more O=00=O
faq sig
