Weber jet question
ToddK
The 45 DCOE's we pulled off of the parts car had two jets under the little round cap with the butterfly wing nut. I assume these are for fuel. One set was labeled 55, and the other set was stamped 135. The barrel which went to cylinder #2 was actually a 115, but I'm assuming that was a mistake not being a 135 like the rest. My question to all of you weber gurus is this. Does that sound like a good base line jetting for a stock motor, or does that sound like it would be for a hopped up one. I think the motor might be built up a little, and here is why. It had a deep exhaust note, the motor shut off instantly when you turned it off, and we got 180PSI across the board when we tested it at wide open throttle.
put 40 DCOE's on a stock motor. 135 mains are in the ball park.
The only way to know for sure would be to drive the car and see how it accelerates against a stopwatch. Also you could see if it pulls well out of a corner. It it is over-carb'd it will stumble badly in the corners.
You could pop the valve cover and see if it has a non-stock cam. That would be a big clue.
Jeff
because you can put different venturis into a 45...
so if you have 30mm venturis, you could be way rich,
but if you have 38's you might be in the ballpark.
Take off the air horn, and shine a light down the bore of the carb.
If you're lucky, you'll be able to see a raised number in the restrictive
'choke' portion of the throat. This is the inside diameter in MM. It's also removable if you take the little safety- wired bolt off the bottom of the carb.
You really should buy the Pat Braden and Haynes Weber books- together, they cost less than a set of idles, air correctors and mains, and if you had them you'd know WHAT an air corrector is!
that's my schpiel, hope it helps,
