why is my oil mixed with water?....still
royrodgers123
I finished replacing my headgasket with resurfaced head, drained all coolant, drained all oil, put in a new oil filter, ran the engine with 2 liters and then drained, repeated three times. I still have milky oil! im not losing coolant. I took the plugs out and cranked her over and no coolant. Im not sure what else to do.
thanks for the help
crack inside the head?
ditto
w/the coolant drained, hookup an air hose w/ about 30psi or so to the system and listen/look for air leaks. if you hear hissing coming through the exhaust, oil fill cap, or intake you might have a cracked head..
..and I also do not own a BMW 2002.
And if you still have a cracked head, you'll still keep blowing your head gaskets. Did you get your head machined before replacing it? Sometimes that can help. Get a head x-ray, that might also help you out.
"My dad was right, it was cheaper just to buy a new car."
'75 Golf Yellow Automatic 2002 with Weber 32/36 DGAV - "Karl"
