K&N air filter
Greg72tii
room under the hood and improved weight bias. It has been said by some that the rear of an 02 is pretty stiff and thus the gains from a rear strut brace are negligible. I suppose if you were tracking the car it might be worth it but a marine battery case and tie-down firmly afixed to trunk floor is sufficient and leaves more room for spare parts.
Paul in Richmond
'70 Chamonix
'85 535i, 2000 R1100R
The general agreement is that the stock filter is the best to the tii.
A K&N or Ramflow may to some look cooler (and is definately louder under WOT) but the stock (helmholtz) airbox is proably the best.
That said, I've not seen a back to back dyno run comparing stock vs. aftermarket that would settle the issue. I'm not taking sides but would love to see a print out. Anybody, Bueller?
fFor me, I've used a K&N and Ramflow. I'm back to stock even though it's harder to change the oil filter as I have to remove at least part of the stock airbox. Just my opinion, but I'd save my money for other things, like driving school.
As always, YMMV
Colin K.
Malaga '72 tii
K&N does make a filter that fits inside of the stock tii air housing. With these you get the best of both worlds! I had them on my old tii. Can't remember the part number, but push come to shove, you can get the stock filter dimensions and match it that way.
The E30M3 SIG did a dyno comparison of different airfilters. ITG, K&N, stock paper, no filter, etc... As I recall, the ITG flowed the best, but only by a small margin over the stock paper filter. The disadvantage with the K&N was that while it flowed better when clean, once it was dirtyit flowed less than the paper filter. If you are very good and keep your K&N cleaned and oiled, they work a bit better than stock. Sure, a dirty K&N probably flows better than a dirty paper filter, but swapping out a $10 filter is usually more often done than pulling and washing and drying and oiling a K&N.
I've run K&Ns in all my cars for years. Once I got the tii, I have reverted back to just using the paper filters and trying to change them out more regularly. I just wasn't keeping up with the washing routine.
Steve J
& too many bikes
  • 7 years later...
There is another option which is the installation of a common triangular filter with a foam element ("Lynx" IIRC), over which a metal grid presses down to hold everything together.
The filter is mounted with a section of appropriate diameter rubber hose (similar to the section of hose used in the K&N filter set up here).
The triangular filter is readily available in most "speed shops" and does not require relocation of the battery.
Regards, Maurice.
