that BMP dash cover
ChuckR
I've test fitted it, and decided to just hold off and find a nice replacement dash one day, or just fix mine - since the crack on mine was not that bad. Consequently, I have a BMP dash cap looking for a new home that I've not listed yet. With the CCA discount, I paid less than $90 actually. Regarding fit, from 5 feet it looks like a new dash, but if you start poking at it, you'll know it's a cap.
S D Gabbard at Yahoo dot com.
Stacey
Columbus, OH
No cup holders, by design.
'76 O=00=O   '77 R100RS  '85 K100 '01 325CI   '05 330XI ZSP   '80 Porsche 911SC
Hello, has anyone tried the BMP dash cover? It's seems pretty affordable (like $90 or so).
thanks chuck
i used one because i want'd to change the color and keep the orignal dash original....i'm very pleas'd with the fit and look...close up, far away, any angle, it looks great
i bought mine from TopsOnline.com...$81.00
Would that dash cover fit a 69 02?
a 69, as you know, has the 2 piece dash...the caps are moulded to fit the one piece dashes...i just pik'd up another dashcap to see if it will work on a 69 dash...in a couple of weeks or so, i'll let everyone know how the caps fit the 2 piece dashes
i see no reason why it won't...there will be a slight void of contact at the rear where the top and bottom meet because it's not as rounded as the 1 pc but i still think, if properly attached, it should work
A 69 should have a 3pc dash. However the dimentions arn't that different from the 2pc. I guess the main diff is that the inst cluster is seperate from the top half. Also, some 3pc dashes didn't have ridges on the parcel shelf area and I guess some did like the 2pc.
I think for the money the caps work well. The only down side is the feel of plastic insted of vinal.
John
1665778
